It is currently Wed Feb 26, 2020 4:22 pm
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Thu Jul 28, 2016 9:35 am
Question from my colleague — Alexander
Good time, experts CDS.
I will try to describe more the problem.
Experiences spend on PI-2 mod.B
There is a controller that has only RS-232, with fixed settings ID 16, 115200,8,N,1.
There is such piece of iron - USR-TCP232-2 http://www.usriot.com/p/rs232-to-ethernet-modules/. Works perfectly in mode RTU over TCP.
But, as You know, CDS are not able to understand this format. Or serial, or TCP.
To solve this problem, I tried to use the socat program http://www.dest-unreach.org/socat/ team socat PTY,link=/dev/ttyCOM tcp:192.168.3.55:502, which creates the most symbolic file /dev/ttyCOM, (lrwxrwxrwx 1 root root 10 Jul 26 10:56 /dev/ttyCOM -> /dev/pts/0)
When experimenting with OpenHab, also had to add the permission to the specified "port" in start.sh -Dgnu.io.rxtx.SerialPorts=/dev/ttyCOM. Although, everything is perfectly functioning.
Now.
By analogy with these often change CODESYSControl.cfg to work with RS-485/USB Converter I tried to add /dev/ttyCOM in the file /etc/CODESYSControl.cfg
[SysCom]
Linux.Devicefile=/dev/ttyCOM
portnum := COM.SysCom.SYS_COMPORT1;
however, nothing happens, not picks up data CoDeSys...
What needs to be done in the /etc/CODESYSControl.cfg [SysCom]
It seems that clearly outlined the problem.
I hope for understanding and help.
PostPosted: Fri Jul 29, 2016 5:08 am
HI,
your symlinc should be:
/dev/ttyCOM0 -> /dev/pts/0
then it will work.
PostPosted: Fri Aug 26, 2016 8:19 am
Thank You, Edwin.
I used to try, but nothing worked. (ttyCOM0)
After Your comment I started to study the problem deeper and found out gateway was created later than the start CoDeSys.
The problem was fixed - it works great!
Decided July 30.
PostPosted: Mon Apr 17, 2017 5:27 pm
hi,
Modbus RTU is bus-faillure(red) when i restart or turn on my rpi, i need to connect with Codesys development and download the app and run.
I made Create Boot App and Sourcecode download.
I tried,
IF Modbus_Slave_COM_Port.xError THEN
Modbus_Slave_COM_Port.xReset := TRUE;
but this doesn't work only change to orange from red.
Thank you.
PostPosted: Mon Apr 17, 2017 5:41 pm
Hi, I've two usb-serial devices from the same manufacturer. I've created udev rules to assing different names for both devices. Names are motor_up and motor_down. Both devices are listed in the /dev folder and both are working fine with minicom. I've added both devices to CODESYSControl.cfg:
[SysCom]
Linux.Devicefile=/dev/motor_up
Linux.Devicefile=/dev/motor_down
portnum := COM.SysCom.SYS_COMPORT2;
No way to make it work :( :(
I appreciate your uggestions..
PostPosted: Mon Apr 17, 2017 5:49 pm
[SysCom]
You can try one by one, with codesys check. Can you show us result about this?
PostPosted: Mon Apr 17, 2017 6:09 pm
I would set symbolic links in Linux
/dev/motor_up -> /dev/ttyMotor0
/dev/motor_down-> /dev/ttyMotor1
and then in /etc/CODESYSControl.cfg only this line will be needed:
[SysCom]
Linux.Devicefile=/dev/ttyMotor
In CODESYS you'll then access com1 for Motor0(Motor_up) and com2 is Motor1(Motor down)
PostPosted: Mon Apr 17, 2017 6:55 pm
Thanks Edwin, now it appears to be working. I've a new question... how to add a line feed + carriage return at the end of the string I am sendig to serial device??
PostPosted: Mon Apr 17, 2017 7:08 pm
$L and $R
PostPosted: Mon Apr 17, 2017 7:21 pm
:D :D
PostPosted: Tue Apr 18, 2017 9:42 am
I have a Modbus Com Error when i reboot my RPI. I share a video. Can you help me pls?
https://drive.google.com/open?id=0B92kE ... nZ2aFYxSms
Hector
PostPosted: Tue Apr 18, 2017 7:10 pm
guess you need to set the autorestart flag?
PostPosted: Wed Apr 19, 2017 9:11 am
Edwin Schwellinger wrote:
Thanks you Edwin,
I tried with autorestart flag too. (bad lucky :cry: )
I'm thinking in reset warm, but I don't know set autoplay after reset.
Hector
PostPosted: Wed Apr 19, 2017 2:55 pm
Dear All,
This topic was so helpfull for me about getting data from usb via codesys.
I used, Edwin's example it works well. I can read data from my usb GPS receiver.
But, i wonder what if i have 2 usb device at the same time.
How we can control both of them at the same time ? It is possible to do it?
For example;
For one usb device we can use
FirstSerialLine(
slMode:= SL_READWRITE,
udiPort:= 1,
udiBaudrate:= 4800,
paParity:= COM.PARITY.NONE,
sbStopBits:= COM.STOPBIT.ONESTOPBIT,
udiByteSize := 8);
what we need to do for 2 usb device at the same time.
Thank you for your help.
PostPosted: Wed Apr 19, 2017 3:18 pm
ekmekci wrote:
Dear All,
For example;
FirstSerialLine(
udiPort:= 1,
udiBaudrate:= 4800,
udiByteSize := 8);
if 2 usb are the same manufacture, you can change udiport:=2 for second device. You can create news string i/o for the second device.
Lucky!
Hector.
