It is currently Tue Feb 18, 2020 1:18 am
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 1 2 3 4 5 6 7 Next
PostPosted: Wed Sep 16, 2015 1:44 pm
I have an USB-Serial-Adapter and followed Edwin's instructions but when I listen to the port (cat /dev/ttyUSB0) there is no response
(sending data via sencond terminal).
Any idea what I do wrong?
Best regards,
Oleg
PostPosted: Wed Sep 16, 2015 6:54 pm
Hi Oleg,
you need to show the /etc/CODESYSControl.cfg
PostPosted: Thu Sep 17, 2015 1:02 pm
Hello Edwin,
thank you for your support!
Best regards,
Oleg
Last line of dmesg:
[ 1399.272505] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
Last few lines of CODESYSControl.cfg:
[CmpCodeMeter]
InitLicenseFile.0=3SLicense.wbb
[SysEthernet]
Linux.ProtocolFilter=3
[SysCom]
Linux.Devicefile=/dev/ttyUSB
portnum := COM.SysCom.SYS_COMPORT1;
PostPosted: Sun Dec 27, 2015 2:53 pm
adding
[SysCom]
in CODESYSControl.cfg
the runtime return STOP - program loaded exception...why?
version is 3.5.8.0
Removing the [SysCom] lines and rebooting it comes back running good (without serial communication of course)
PostPosted: Mon Mar 21, 2016 3:31 pm
Hello Edwin,
I am trying to use the project from this forum "http://forum.codesys.com/download/file.php?id=604"(SerialComWithVisuRaspi.projectarchive). After updating all necessary components There is still an error in ComOpen function parameter "usiListLength:= SIZEOF(aParameter) / SIZEOF(COM.PARAMETER)". Can not convert type UINT to type USINT. Where is a problem?
Peter
PostPosted: Mon Mar 21, 2016 8:25 pm
Hi Peter,
attached an updated Version to current 3.5.8.10
PostPosted: Tue Mar 22, 2016 7:02 pm
Hi Edwin,
I downloaded suggested version, but the error still persist. There is a mismatch between types UINT AND USINT. See ComOpen function parameter "usiListLength:= SIZEOF(aParameter) / SIZEOF(COM.PARAMETER)". Can not convert type UINT to type USINT.
PostPosted: Tue Mar 22, 2016 7:05 pm
which CODESYS Version are you using?
Which Raspberry PI Package Version?
PostPosted: Wed Mar 23, 2016 9:36 am
I use CODESYS V3.5 SP8 and CODESYS Control for Raspberry PI_3.5.8.0.package
Peter
PostPosted: Sun Apr 03, 2016 4:44 pm
Hello. I want to use internal serial port AND extrnal usb-com adapter.
I tried to add this to /etc/udev/rules.d/serial-symlinks.rules
SUBSYSTEM=="tty", ENV{DEVPATH}=="/devices/platform/soc/20201000.uart/tty/ttyAMA0", SYMLINK+="tty-RPI0"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.2:1.0", SYMLINK+="tty-RPI1"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.3:1.0", SYMLINK+="tty-RPI2"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.4:1.0", SYMLINK+="tty-RPI3"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.5:1.0", SYMLINK+="tty-RPI4"
And this to /etc/CODESYSControl.cfg
[SysCom]
Linux.Devicefile=/dev/tty-RPI
But it doesn't work(
PostPosted: Sun Apr 03, 2016 6:41 pm
does a
cat /dev/tty-RPI0
and cat /dev/tty-RPI1
work under Linux?
(If you connect a terminal to port and send....)
PostPosted: Mon Apr 04, 2016 2:31 pm
Hello. Now everything working.
I changed platform-bcm2708_usb-usb-0:1.2:1.0 to platform-20980000.usb-usb-0:1.2:1.0 for my RPI B+
sudo nano /etc/udev/rules.d/serial-symlinks.rules
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-20980000.usb-usb-0:1.2:1.0", SYMLINK+="tty-RPI1"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-20980000.usb-usb-0:1.3:1.0", SYMLINK+="tty-RPI2"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-20980000.usb-usb-0:1.4:1.0", SYMLINK+="tty-RPI3"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-20980000.usb-usb-0:1.5:1.0", SYMLINK+="tty-RPI4"
sudo nano /etc/CODESYSControl.cfg
[SysCom]
PostPosted: Mon Apr 04, 2016 8:35 pm
Thanks for the feedback,
helpful for others too.
PostPosted: Mon May 02, 2016 7:25 pm
Hello Edwin,
i open the project linked in your last post with attachement (SerialComWithVisu.project),
wehn i open it i become lot of errors: Library SM3 is not available.
I use the last version of Codesys 3.5 and Raspi Package 3.5.8.10 .
Can you Help me?
Serghei
PostPosted: Mon May 02, 2016 8:02 pm
Hi Serghei,
open older Projects should allways followed by the following procedure:
1. Update the plc device in the device tree (right click update device)
2. if there are fieldbus stacks used in the Project (update them too)
2. set current compiler version
3 set current visu profile
This usually give a error free - updated project ready for using it.
