It is currently Tue Feb 18, 2020 2:41 am
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Sun Oct 26, 2014 11:17 am
Hello Edwin,
Thank you for your prompt answer.
I modified the file CODESYSControl.cfg (I have just understood that I had to do the modification on the Raspberry side, sorry...).
Now, it's done.
I added 0 to ttyUSB to have ttyUSB0 but it doesn't work anymore (I tested again with minicom & it was working on ttyUSB0 !)
on a window side (in Codesys) I tested
- udiPort:= 0, and
- udiPort:= 1,
without success, I have the same ERROR_UNKNOW !
Do you have another suggestion or idea where the issue comes from ?
thank you
Christian,
PostPosted: Sun Oct 26, 2014 5:01 pm
Hi Christian,
if your serial port is ttyUSB0
your config fileCODESYSControl.cfg should be without the '0'
[SysCom]
Linux.Devicefile=/dev/ttyUSB
that's it.
Regards
Last edited by Edwin Schwellinger on Tue Apr 18, 2017 5:59 am, edited 1 time in total.
PostPosted: Sun Oct 26, 2014 7:23 pm
Hi Edwin,
thank you for your patience, now it works very well.
thank you again,
PostPosted: Fri Nov 21, 2014 1:41 pm
I managed to fix COM port numbers COM1-COM4 to USB sockets on Raspberry Pi B+ :D .
This is the procedure:
-sudo nano /etc/CODESYSControl.cfg
Add this:
[SysCom]
Linux.Devicefile=/dev/tty-RPI
portnum := COM.SysCom.SYS_COMPORT1;
-sudo nano /etc/udev/rules.d/serial-symlinks.rules
Add this:
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.2:1.0", SYMLINK+="tty-RPI0"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.3:1.0", SYMLINK+="tty-RPI1"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.4:1.0", SYMLINK+="tty-RPI2"
SUBSYSTEM=="tty", ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.5:1.0", SYMLINK+="tty-RPI3"
-Reboot
That's it! :lol:
Best regards,
Zdenko.
PostPosted: Thu Mar 05, 2015 4:16 pm
How can I get Error status bit for Modbus_COM_1?
Best regards,
Zdenko
PostPosted: Thu Apr 16, 2015 1:02 pm
Sorry, posted in other topic...
viewtopic.php?f=21&t=5986&p=12004#p12004
Osman
PostPosted: Fri May 22, 2015 9:05 am
i have problems to read from COM in Codesys.
I modified the Project from this thread. I´ve connected a PILZ PNOZmulti with USB to the Raspberry. The USB-Serial Converter works with an FTDI chip. The comWrite send the hex string i want to the PILZ. When i use the Terminal with:
stty -F /dev/ttyUSB0 192000
stty -F /dev/ttyUSB0 raw
cat /dev/ttyUSB0 | od -tx1
the right answer comes back in hex. But i can´t get codesys to recognise it. The ReadBuffer is always empty. Whether i use a timer after the comWrite or not.
Any suggestions?
Best regards,
Daniel
PostPosted: Sat May 23, 2015 6:02 am
Hi nosi,
could you attach /etc/CODESYSControl.cfg to this post or at least check if your entry for your SerialCom
device is in. (This is what you need to add manually)
in your case it is:
[SysCom]
Last edited by Edwin Schwellinger on Tue Apr 18, 2017 6:00 am, edited 1 time in total.
PostPosted: Thu May 28, 2015 8:28 am
Hello Edwin,
thank you for answering. I checked the .cfg . But i added the lines manually before.
I found the problem. Somehow another programm cut the connection.
Best Regards,
Daniel
PostPosted: Fri Jun 12, 2015 12:30 pm
Hi everyone! How to configure the RAspberry UART port in Linux?
I did only this:
[SysCom]
Linux.Devicefile=/dev/ttyAMA
But have an error;
PostPosted: Sat Jun 13, 2015 11:46 am
more details... which error an where do you see the error ?
Could you use AMA0 in the console in Linux?
Last edited by Edwin Schwellinger on Sun Jun 14, 2015 7:45 pm, edited 1 time in total.
PostPosted: Sun Jun 14, 2015 11:26 am
Edwin Schwellinger wrote:
more Details... which error an where do you see the error ?
Good afternoon. I can't attach a screenshot at this topic, have some error;
I use handmade converter on ST485 and npn transistors wich switch direction of USART transmission data. In Raspbian I'm configuring only this - sudo nano /etc/CODESYSControl.cfg
I have configured after
Master device modbus config in Codesys: 9600, 8E1;
Settings in slave device: adress#1, 9600, 8E1
When I login via Codesys, mastes device is run ok (green circle near Master device in Codesys), but slave not response and i have an erron "Bus is not run";
Auto reconection on bus enabled;
How can I check UART in Linux console? And what I must configure in Raspbian for working USART?
BR. Osman
PostPosted: Mon Jun 15, 2015 4:14 am
Hi Osman,
use a terminal and the following: (sure in your case you need a USB-RS485 converter on Windows to test )
viewtopic.php?f=21&t=5699#p10300
next step could be - use the serial example and a terminal.
Last step is use modbus with your device
PostPosted: Tue Jun 16, 2015 4:03 pm
Hi Osman,
I conect USB-RS485 converter on Win PC and raspberry...
ttyAMA0 does not transfere the data;
PostPosted: Wed Jun 17, 2015 1:56 pm
Hi everyone I've solved problem. Problem was in electronic circuit on ST485. I've deleted one transistor and connected PIN4 to the GND. On Raspberry I did this:
cp /boot/cmdline.txt /boot/cmdline.bak
cp /etc/inittab /etc/inittab.bak
Next: sudo nano /boot/cmdline.txt
delete this string "console=ttyAMA0,115200" и "kgdboc=ttyAMA0,115200"
Next: sudo nano /etc/inittab
and change string: T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100 to #T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
Thank you very much for help!
Osman.
