Pulse/Direction SoftMotion Axis
jzhvymetal
2014-03-27
2018-04-23
  • jzhvymetal - 2014-03-27
    Is there anyway to turn GPIO or an I2C/SPI board to run a Pulse/Direction Axis? I want to use it to control steppers with a stepper driver using Softmotion Library. If so I would like to test with 3D Delta printer.
  • kursadaltan - 2015-11-01
    Any answer?
  • Alan - 2018-03-05
    This is very interesting to me too, anybody knows the answer?
  • eschwellinger
    eschwellinger - 2018-03-07
    i agree these puls/direction steppers would be useful for many applications but
    it is no easy possible to use them by the GPIO's. ( there is no Driver available for SoftMotion and guess you need for sure additional harware / Extension board / whatever)
    At the moment only the EL2521 by using Ethercat solution is running out of the box including SoftMotion driver
    IMG: EL2521.jpg
  • McNugget2000 - 2018-04-23
    Hello.
    I´m struggling with the same Problem.
    This device seems to be the solution:
    http://pthat.com/
    The last Problem i have ist the serial Communication.
    Regards
    McNugget
  • Alan - 2018-04-23
    McNugget2000 hat geschrieben:
    Hello.
    http://pthat.com/
    Regards
    McNugget
    It looks good. Did you already tried it? Do have easy access by codesys?
    Sent from my SM-G950F using Tapatalk
    Hello.
    Unfortunately i wasn´t able to try. I´m waiting for the Hardware.
    At the moment i try to solve problems with webvisu and RS232 Communication.
