HMI is running on a remote pc connected via dataserver to the plc (in your case Raspberry Pi)
Check the online help for 'Basics to CODESYS HMI'-
you could add 'HMI' in your project and then click on 'Create HMI' then you have a second application in your project as
result which you could download to the HMI pc.
As I know this is an extra license (not sure see only the device which you got with CODESYS installation) - for the hmi device
plcmax
I know I can use the webvisu but in a project I am able to add HMI Visualisation as well.
How do I use this, either on a "remote" computer or local on the rpi?
Not clear what you mean..
Sent from my AN10DG3 using Tapatalk
plcmax
