It is currently Tue Feb 19, 2019 3:31 am
Post new topic  Reply to topic  [ 65 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Re: CAN trough SPI ?
PostPosted: Wed Oct 19, 2016 4:28 pm
I do have exactly the same problem, that I can not get CANopen running properly.
My setup is: 2x Raspberry Pi 3 with CanberryDual 2.1, connected to each other. SocketCAN is working properly and I can send CAN messages from one Raspberry Pi to the next and vice versa. Also in CodeSys, the SocketCAN driver is working properly as CAN messages are received if I configure one Pi as a CANopen slave that produces heartbeat messages.
What I did is configure one Pi as a CANopen slave, export the EDS file to the other Pi that adds this CANopen device.
However, the CANopen manager says it is not running. After added CANOPEN_DEBUG, I noticed in the PLC log that it remains stuck in the SDO exchange phase. The message is: SDO read timeout for object 16#1000sub16#00, AbortCode: 16#05040000.
Appreciated if someone can give some guidance what goes wrong here?
PostPosted: Sun Oct 22, 2017 8:56 pm
Hello everybody,
first thank you very much for the fantastic descriptions.
I got everything running with J1939.
But why couldn't i get it running with CANOpen? Which CANOpen-Modul in Codesys do i have to choose.
Thanks for helping
Timo
Ich freue mich besonders über die Besucher auf meinem Blog die auch einen Kommentar hinterlassen...
PostPosted: Fri Mar 02, 2018 5:57 pm
PI can success with NiRen Pi mcp2515... was one problem.. in /boot/config.txt
dtparam=spi=on
dtoverlay=mcp2515-can0,oscillator=8000000,interrupt=25
dtoverlay=spi1-2cs
I have 8Mhz oscill .. and maximum speed limit on Canopen 500kbs. For 1Mbs needed 16Mhz osill on canoprn board.. and chip selesct in my case 2nd dtoverlay=spi1-2cs
From another sime PC with Runtime and PeakUSB working fine. Pi was tested as salve and as master on canopen bus.
And have to connect 5V separate to TJA1050 as here descrbed. https://vimtut0r.com/2017/01/17/can-bus ... nel-4-4-x/
PostPosted: Thu May 24, 2018 3:51 pm
[quote="yannickasselin1"]Hi everyone,
I followed all the steps above and CANbus and CANopen_manager seem to work fine but I still cannot communicate with my Festo Servo Drive through CANopen.
Can someone help me please.
Yannick, Did you ever resolve this problem? I am trying to do the exact same thing with RPI and 3 axis CMMP-AS. Please let me know if you did.
PostPosted: Fri May 25, 2018 8:39 am
You can show screen with PDO and SDO configuration?
