I'm using Codesys Runtime on RPi for lab equipment and it's gorgeous for it's money with EtherCAT support etc. But now I would like to start experimenting with CAN and CANopen. I see, that CANopen for RPI shall be available according to the runtime datasheet, but don't see any examples on how to make it working. I also interested in simple CAN first, before starting with CANopen.
Can Codesys developers help and provide some material or tutorial on:
- What additional HW is needed? I have couple of USB-CAN adapters from Ixxat and Peak. Will they work with Codesys? Datasheet suggests only EL6751 terminal - is it the only HW supported?
- How to setup Codesys to work with CAN and CANopen using this HW on Rpi? Any simple project which reads or writes CAN messages would be appreciated.
- Any common errors, debug solutions?
My plan is to build a simple CAN logger for lab purposes first and then move to more complex things.
Hello, if you are using e.g. the debian buster based Os the PeakCANUSB-adapter is already supported with SocketCan. If you want to use this in CODESYS you have only to enable the component in the CODESYSControl_User.cfg. Then you could direct use the CanBus adapter and all protocoldevices like CanOpen.
Dear Codesys fans and developers,
Thank you.
UPD just found this http://www.industrialberry.com/can-bus-with-codesys/ m
Have you solved your problem?
Hi Syoma,
adapter support on Linux is related to SocketCAN support in kernel, so Peak will definitely work. I read online that the Ixxat proprietary SocketCAN driver has some problems, so I'd stay away from that.
Codesys support of CAN layer 2 is a bit hairy, you can refer to the library documentation here: https://help.codesys.com/webapp/hGcF55fadXXw7LxTlfIUoErJcVQ%2Ffld-CAN-Low-Level;product=CAA%20Can%20Low%20Level%20Extern;version=3.5.17.0
whereas for CANopen you can just drop a CANbus device as a subdevice of your PLC and then a CANopen manager and/or a CANopen slave under it: https://help.codesys.com/webapp/_can_f_canbased_field_busses;product=core_canbus_configuration_editor;version=3.5.17.0
Last edit: bruno-roth 2021-12-09
Also this USB to CAN adapter is working:
https://www.amazon.de/gp/product/B07Q812QK8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&th=1
with the same configuration I used with the PeakCAN Adapter. It is really plug and play.
