It is currently Mon Dec 09, 2019 9:39 pm
PostPosted: Thu Nov 14, 2019 10:33 am
While Booting PLC is going in exception because of the array structure for Persistent variable.
can this error be overcome by using Memory card and using memory card for Boot project.
PostPosted: Thu Nov 14, 2019 8:32 pm
Hi Raj,
Can you explain further the blame on "array structure for persistent variables"?
When you double click the exception to go to source position where does it take you?
Which WAGO PLC?
If you go View > Call Stack.. you will see where in the code the error is.
PostPosted: Fri Nov 22, 2019 10:55 am
I suggest you to boot the PLC with Run/Stop selector to Stop (void access violation in your persistent array), fix and download the code them switch the PLC to run
Users browsing this forum: erossg and 6 guests
