J've got an error message after trying to load my project in my Raspberry pi3 (with CODESYS V3.5 SP15 Patch 1)
Error message " Download KO; Disk full".
I reinstalled rasbian to solve the problem. But i'm not sure it is the good solution and I fear that problem will come again.
This problem leads me to ask questions :
Where does CODESYS store the project, on the SD card or on the RAM memory ? (I use a 32 Go SD Card !!)
How to be sure to reset the memory, becouse when I get my problem, it seems the "Reset Origin command" don't resolve the problem.
Thank you in advance for your ideas.
"Reset origin" - reset the application including all varibales to init value(retains too) -
"Reset-origin-device" does remove the whole application (bootapplication is removed too) inclduing all files which have been downloaded to the plc- ( even files which are not in the project anymore)
imagine you play around with different applications on the PI, then you have different images/icons downloaeded/ - they will never removed.
After doing this a new 'full' download of the application is needed!
HI Joseph,
Thank you for the idea.
I know this expansion with older versions of Rasbian.
With Rasbian Stretch, this option does not exist in the graphical configurator.
Anyway before having the problem described, I had already successfully used my raspberry with this program and this version of rasbian.
The problem occurred after a program reload after a program change.
I suppose there was a phenomenon that disrupted memory, a big file, or something else.
If the problem comes back I will test the memory with the command that Edwin told me.
all application relatated files are stored in:
/var/opt/codesys/PlcLogic/
I would exclude that CODESYS does fill a 32g SD card.
You could remove all CODESYS transfered files by:
Reset-origin-device command.
Maybe you could check in the CLI
find / -type f -size +5000k
if there are huge files in the system.
Hi Edwin,
Thank you.
If the problem come again I will check with you command.
What is the difference between the "Reset-origin-device" command and the "Reset origin" command in the in Line menu ?
Hi.
When you install raspbian from an image for first time, it has format an small part of the total disk space.
You can go to raspi_config and there is an option to wxpant filesystem to the totality of your sd.
HI Joseph,
Hi Japib
I have a problem due a new downloads caused by a bad gestionof dynamic memory in FB_exits.
