It is currently Wed Jan 16, 2019 11:40 am
PostPosted: Sun May 06, 2018 10:48 am
hello, I have a raspberry card and I manage two Controllino maxi for home automation management with codesys.
The two controllers are connected in modbus slave and work great.
On the same network I then have another raspberry, located in the room, which I use as a magic mirror.
Now I would like to be able to control the air conditioner and detect the temperature with that raspberry.
To do this, do I need to install a codesys license on this raspberry too?
Thanks, Alberto
PostPosted: Tue May 08, 2018 12:29 pm
hi all, how can I make a raspberry a tcp modbus slave?
I already have a raspberry with codesys so I would like to connect a simple raspberry with modbus tcp slave protocol and check it from codesys
Thanks, Alberto
PostPosted: Wed May 09, 2018 6:04 am
you only need the Raspberry PI runtime license (no additional modbus license)
here in the Pi application section in this Forum is an example project for doing this:
viewtopic.php?f=21&t=6884
Modbus project with 2 Pi's.
PostPosted: Wed May 09, 2018 6:46 pm
But I thought it was like with arduino.
Install the pymodbus library on raspberry and check it from codesys as in arduino.
PostPosted: Mon May 14, 2018 6:34 pm
Good evening, I managed to connect a remote raspberry with pymodus with the following code.
from pymodbus.server.async import StartTcpServer
from pymodbus.device import ModbusDeviceIdentification
from pymodbus.datastore import ModbusSequentialDataBlock, ModbusSlaveContext, ModbusServerContext
import RPi.GPIO as GPIO
import os
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
#set up Raspberry GPIO
def main():
   store = ModbusSlaveContext(
      di = ModbusSequentialDataBlock(0, [0]*100),
      co = ModbusSequentialDataBlock(0, [0]*100),
      hr = ModbusSequentialDataBlock(0, [0]*100),
      ir = ModbusSequentialDataBlock(0, [0]*100))
   context = ModbusServerContext(slaves=store, single=True)
   identity = ModbusDeviceIdentification()
   identity.VendorName  = 'pymodbus'
   identity.ProductCode = 'PM'
   identity.VendorUrl   = 'http://github.com/simplyautomationized'
   identity.ProductName = 'pymodbus Server'
   identity.ModelName   = 'pymodbus Server'
   identity.MajorMinorRevision = '1.0'
   StartTcpServer(context, identity=identity)#, address=("localhost", 502))
if __name__ == "__main__":
   main()
Now I would like to map the outputs and the gpio revenue into codesys.
In particular I would like to read the value of a probe ds18b20 connected to that pi.
Do you help me insert the python code and map the exit in codesys?
Thanks, Alberto
PostPosted: Tue May 15, 2018 9:28 am
.... I'm almost there.
I read the ds18b20 on codesys !!
I just need to be able to control the heat pump on that raspberry and I finished :P
PostPosted: Thu May 17, 2018 10:15 pm
Well, I've decoded the infrared remote control for the heat pump and managed by python.
Now I just have to put everything together on codesys :shock:
PostPosted: Fri May 18, 2018 11:01 pm
Hi guys, I'm almost straight for arrival but I still miss what little that makes me sleep.
Below I put the code that must run on the PI on which pymodbus runs.
import time
import argparse
import sys, traceback
import threading
import smbus
import subprocess
import pymodbus
from pymodbus.datastore import ModbusSlaveContext, ModbusServerContext
from pymodbus.register_read_message import ReadHoldingRegistersResponse
from pymodbus.client.sync import ModbusTcpClient
from pymodbus.server.sync import ModbusTcpServer
global server
global ip
def ServerThread(e):
   global server
   # Configure the service logging
   #import logging
   #logging.basicConfig()
   #log = logging.getLogger()
   #log.setLevel(logging.DEBUG)
   # Initialize your data store
   # Initialize the server information
   identity.VendorName  = 'Pymodbus'
   identity.VendorUrl   = 'http://github.com/bashwork/pymodbus/'
   identity.ProductName = 'Pymodbus Server'
   identity.ModelName   = 'Pymodbus Server'
   # Run the server
   server = ModbusTcpServer(context, identity=identity, address=(ip, 502))
   print ("Server started")
   server.serve_forever(0.1)
   print ("Server stopped")
def Clima(update_interval, e):
        #Gestione del climatizzatore
   print ("Clima")
   client = ModbusTcpClient(ip)
   while True:
                rr = client.read_holding_registers(0x000A,1,unit=UNIT)
                assert(rr.function_code < 0x80)     # test that we are not an error
                if rr.registers[0] == 1:
                        subprocess.call(["irsend", "SEND_ONCE", "AnalysIR", "ACCENDI"])
                        #print (cmd)
                        time.sleep(0.01)
                        client.write_register(0x0008, 100)#VERIFICA
                elif rr.registers[0] == 2:
                        subprocess.call(["irsend", "SEND_ONCE", "AnalysIR", "SPEGNI"])
                        #print (cmd)
                        time.sleep(0.01)
                        client.write_register(0x0008, 0)#VERIFICA
                elif rr.registers[0] == 3:
                        subprocess.call(["irsend", "SEND_ONCE", "AnalysIR", "MODO_VENTILATORE"])
                        #print (cmd)
                        time.sleep(0.01)
                        client.write_register(0x0008, 101)#VERIFICA
               break
client.close()
print ("Clima thread stopped")
def TemperatureUpdateThread(update_interval, e):
        #Scrivo la temperatura nel registro 0x0000
   print ("TemperatureUpdateThread")
   while True:
      if not e.isSet():
         tfile = open("/sys/bus/w1/devices/28-0117c15d88ff/w1_slave")
         text = tfile.read()
         tfile.close()
         secondline = text.split("\n")[1]
         temperaturedata = secondline.split(" ")[9]
         temperature = float(temperaturedata[2:])
         client.write_register(0, temperature)
         print (temperature/1000)
         time.sleep(update_interval)
      else:
         break
   client.close()
   print ("Temperature 0 sensor thread stoped")
   global server
   global ip
   print ("=== Modbus Device ===")
   parser = argparse.ArgumentParser(description='Modbus server')
   parser.add_argument('ip',  default='localhost', help='IP adress of modbus server')
   args = parser.parse_args()
   ip = args.ip
        e_exit = threading.Event()
        thServer = threading.Thread(name='ServerThread', target=ServerThread, args=(e_exit,))
        thTemperature = threading.Thread(name='TemperatureUpdateThread', target=TemperatureUpdateThread, args=(1, e_exit,))
        thClima = threading.Thread(name='Clima', target=Clima, args=(1, e_exit,))
        UNIT = 0x01
   # Init hardware
        GPIO.setmode(GPIO.BCM)
        GPIO.setwarnings(False)
   thServer.start()
   time.sleep(1)
   # Start clients
   time.sleep(1)
   thTemperature.start()
        time.sleep(1)
        thClima.start()
   # Wait for keyboard interrupt
   try:
      while True:
         time.sleep(1)
   except KeyboardInterrupt:
      print ("Stopping program")
   except Exception:
      traceback.print_exc(file=sys.stdout)
   # Set stop event for clients
   e_exit.set()
   # Shutdown server
   server.shutdown()
   # Wait until server shutdown
   while thServer.isAlive():
      time.sleep(1)
   # Clean up
   GPIO.cleanup()
   # Stop the program
   print ("Done")
   sys.exit(0)
With this code I send on codesys the value of the temperature from the ds18b20 and contains code that controls the air conditioner.
For the temperature everything is ok.
The problem is with the commands to the air conditioner.
The Climate thread works as it is but with a small but important flaw.
When executing last command, elif leaves the thread
I'm not familiar with Python, and by copying / modifying this piece of code found on the internet I understand that python uses indentation as terminators.
Now I can not figure out how to fix this my little / big problem.
Can you help me?
Thanks, Alberto
Users browsing this forum: Andreas Kehrer and 5 guests
