CODESYS - the IEC 61131-3 automation software https://forum.codesys.com/ |
Web Client https://forum.codesys.com/viewtopic.php?f=20&t=9875 |
Page 1 of 1 |
Author: | ssl [ Thu Jul 11, 2019 10:01 am ] |
Post subject: | Web Client |
Hi, I have tried to use Web client package version 1.0.0.2 (according to store it requires minimum verison 3.5.10.0) in a runtime version 3.5.10.50. However when I add the library reference it adds additional components and one of them is the CmpX509Cert library version 3.5.11.0. So when I download to target it says that there is a version conflict. Upgrading the target version is not an option however!! Does anyone know a work around for this? Does the CmpX509Cert come in a veriosn 3.5.10.50 (or older)? Is the minimum requirements in the store wrong? Thanks! |
Author: | Edwin Schwellinger [ Fri Jul 12, 2019 8:41 am ] |
Post subject: | Re: Web Client |
Hi, should work, could you check if in the library manager the placeholders are manually changed? There should no lib appear in Version > 10 BR Edwin |
Page 1 of 1 | All times are UTC+01:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
