It is currently Tue Apr 23, 2019 3:25 pm
PostPosted: Wed Jan 16, 2019 10:37 pm
Hello
I would need some help to use the KNX SL feature on a Raspberry Pi 3B+.
License of CODESYS Control for Raspberry Pi SL and CODESYS KNX SL was installed on a CODESYS Runtime Key.
I’m on : Raspberry Pi 3B+ with Codesys 3.5.14.0
ETS 5.6.6 (Build 1190) with DCACodeSys 1.0.0.0 installed.
Do you have an example of a project using CODESYS KNX? (Codesys Project + ETS Project)
For the moment, even with the installation of DCACodesys, I don't understand how to add a Codesys Device in my ETS project, do not I need a KNXProd file to be able to add the device to my catalog.
Would not it be necessary to import a KNXProd file to my catalog ?
In ETS, I can see a Line "3S-Smart Software Solutions GmbH" in the Online Catalog Settings Tabs.
But in the Catalogs Tabs, there is nothing ?
Next In codesys how can I use KNX ?
Thanks.
 Post subject: Re: KNX SL - HOWTO
PostPosted: Thu Jan 17, 2019 1:20 am
https://forum-de.codesys.com/viewtopic. ... 7&start=30
PostPosted: Fri Jan 18, 2019 12:59 am
Thanks for your link even if it's in german :oops:
I notice there are some diff between Codesys 3.5.13 and 3.5.14.
In the KNX device tab, I can't see the General Tabs in Codesys 3.5.14 , instead of the Gneral Tab, there is a KNX Parameters Tab instead.
So how do you create a point?
See my file capture.
For the moment I switch to Codesys 3.5.13 and It's OK.
The process for using the KNX is similar to that used by wago and their terminal 753-643
On the other hand I find the process of "download Application" in ETS extremely long.
I hope you could improve this.
