It is currently Wed Mar 20, 2019 12:47 pm
PostPosted: Fri Dec 04, 2015 10:15 am
Hi All,
How can I add some result values to a Test Report?
With the command "TestManager.Testreport" and "AddResultInformation" can I add text. How can I add a variable value which is read with the "ReadVariable" command.
The next software is used: Codesys V3.5 SP7 Patch 2 and Test Manager 4.0.1.1.
PostPosted: Fri Dec 04, 2015 2:02 pm
Hi Bakkertje.
1. Configure a output parameter for ReadVariable and copy the parameter name into the field "Test script variable"
2. Configure a input parameter for AddResultInformation and add the parameter name in curly brackets (placeholder) in your text for the test report
Martin
PostPosted: Fri Dec 04, 2015 4:28 pm
Hi Martin,
Thanks that works fine.
What is the syntax to use a Carriage Return and Line Feed?
I try this:
Test project on target: {sTargetName} {\r\n}
With a timeout setting: {iTimeout} "\r\n"
An other line \r\n
But it is all printed on the same line.
PostPosted: Mon Dec 07, 2015 8:37 am
Hi Bakkertje.
You can use XHTML tags for formatting. For a new line you have to use: <br/>
Martin
PostPosted: Mon Dec 07, 2015 10:36 am
Hi Martin,
Thanks that works fine. :lol:
