It is currently Thu Feb 27, 2020 5:49 pm
PostPosted: Sat Aug 25, 2018 8:17 am
Good morning,
I am programming an IFM PLC, CR2532 communicating by CAN to a CR0451 panel.
I can not exchange the network variables between PLC and HMI.
The CAN wiring is correct because I can send code to the PLC and HMI from Codesys 2.3 and the "Maintenance" application from IFM.The wiring is according to the IFM manual "ecomatmobile", page 230.
Since IFM I have sent tutorials and information and even then, there has been no way to exchange a single variable.
The configuration that is currently in the installation is as follows:
PLC CR2532, ID: 126
HMI CR0451, ID: 1
The application I want to do is very simple, exchange bool variables from PLC to HMI, to see the status of inputs and outputs of the PLC, and from CR0451 to send bool variables, to select some options.
If someone has a tutorial or small program that works with this PLC-HMI and exchanges these variables, I would greatly appreciate it, since I am a bit blocked ...
Attached screenshots of the current application loaded to the PLC and HMI, of the network variable settings, etc.
