It is currently Mon Feb 18, 2019 3:15 am
CoDeSys Version 2.3.9.53 cannot implement all the functions of IEC 61131-3
Yes, it can. 0%  0%  [ 0 ]
No, it cannot. 100%  100%  [ 1 ]
Total votes: 1
PostPosted: Thu Sep 21, 2017 4:00 am
Software: CoDeSys V2.3
Function to achieve: control the traffic lights
Problem: The POU PLC_PRG is written in SFC using IEC-Steps. There are three compiling errors which I cannot eliminate even though the help documents contain corresponding explainations.
at Transition T002,
Error 4355: A transition may not have any side effects (Assignments, FB-Calls etc.)
in line 3 at Transition T002,
Error 4370: PLC_PRG (3): Superfluous lines found after correct IL-transition.
in line 1 at Transition T001,
Error 4371: Transition T001 (1): Invalid characters following valid expression: 'T001 := START;"
T001
T001 := START;
T002
ST  TON_2.IN
LD  T#8S
ST  TON_2.PT
CAL  TON_2
LD  TON_2.Q
ST  T002
Some clues:
In the help docs of CoDeSys V2.3,
A transition condition must have the value TRUE or FALSE. Thus it can consist of either a boolean variable, a boolean address or a boolean constant. It can also contain a series of instructions having a boolean result, either in ST syntax (e.g. (i<= 100) AND b) or in any language desired (see 'Extras' '_ Action/Transition'). But a transition may not contain programs, function blocks or assignments!
In the help docs of CoDeSys V3.5,
CODESYS Development System > Reference, Programming > Programming Languages and their Editors > . Sequential Function Chart (SFC) > Elements > SFC Elements 'Step' and 'Transition'
As opposed to CoDeSys V2.3, now CODESYS treats a transition condition like a method call. The entry has the following syntax:
<transition name>:=<transition condition>
(for example trans1:= a=100)
or only
(for example a=100)
Users browsing this forum: Andreas Kehrer and 2 guests
