It is currently Sat Dec 07, 2019 2:51 pm
PostPosted: Thu Sep 14, 2017 1:01 pm
a simple code:
PROGRAM PLC_PRG
VAR
A: REAL:=50.0;
B: REAL:=50.15;
C:REAL;
END_VAR
C:=A-B;
C value is -0.1500015 ? Why?
I'm using 2.3.9.53
PostPosted: Thu Sep 14, 2017 5:45 pm
Accuracy limits of REAL type. If you need higher accuracy, then you need to use LREAL, if it is supported on your platform.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Fri Sep 15, 2017 6:24 am
mmm....I don't think is the REAL data type limit...by doing the same calculation on codesys 3 is ok. Or by trying to adding (50+50.15=100.15 , not 100.1500015..)the result is correct. I think is something related to the fraction and exponent management ...
No one had the same trouble?
PostPosted: Mon Sep 18, 2017 10:07 pm
You are hitting accuracy errors. Keep in mind that 0.15 is a repeating number in base 2, so depending on internal implementation, you will have an error when you define the value because of truncation. Also, I am pretty sure you will see more accuracy problems with 50-50.15 (negative, fractional number) than with 50 + 50.15. This page (http://ccm.net/contents/62-representati ... d-integers) gives an explanation of how real numbers are stored as a 32 bit number.
This calculator (https://baseconvert.com/) shows:
-0.1500000 = -0.0010 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 1
-0.1500015 = -0.0010 0110 0110 0110 0111 1111 1001 0000 1101 1001 1101 0111 0111 0111 0100 1010 1
Bit deviation starts at bit 20 (23 bits would be absolute max performance, based on 23 bit mantissa)
Now, if we look at your 50-50.15:
50.00 = 11 0010.0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0
50.15 = 11 0010.0010 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 0110 1
50.00 will be: 1.10010000000000000000000 e^(127+5) s=0, m=10010000000000000000000, e=10000100
50.15 will be: 1.10010001001100110011001 e^(127+5) s=0, m=10010001001100110011001, e=10000100
Ultimately, you are subtracting a truncated repeating number, so error will appear sooner.
I created a project with CoDeSys 3.5.6.66 that has an error already with 50.15 (as expected) - see the screen shot. I also used 50.5 instead, and received a "perfect" answer (because 0.5 is 0.1 in base 2 notation). See screen shots.
Are you sure your CoDeSys 3 test was still using 32 bit REALs? With LREAL, you will see -0.15 in the online debug mode, but not in the variable header - you will see truncation error of infinite repeating 0.15 in base 2:
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Thu Sep 28, 2017 6:59 pm
REAL is not exact, so you can see a small deviation.
the same can be done on a simple calculator, just add 1 and after 1 million times the result will not be exact.
It is indeed to do with the way the mantisse works, as it is not endless resolution.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
