It is currently Fri Feb 21, 2020 7:01 pm
PostPosted: Sat May 06, 2017 5:59 pm
Hello, I am a bit of a newbie to the whole programming world but have learnt a fair bit over the passed few months. My latest stumbling block is writing to a csv file created in my programme on the pi. I can create the file successfully, and write to it each time a :BOOL is triggered TRUE. However each time I trigger this switch, I overwrite the existing data. I am using .CAA library.
Where am i going wrong in the code below, this is taken from the example in the help section and amended slightly for my string/ triggers. I first of all create a file with one case/one :BOOL name RUN. Then the file is opened again in the Append mode by :BOOL named FiWr but still seems to overwrite each time is triggered rather than adding to the end of the file
Var
RUN: BOOL;
FiWr: BOOL;
FINSTR:= CONCAT(SEMFINSTR,'$R$N');
csvwrite:= UDINT:=0;
xFileStdInit:= RUN;
IF NOT xFileStdInit THEN
filop(xExecute:=FALSE);
filcl(xExecute:=FALSE);
filwr(xExecute:=FALSE);
filrd(xExecute:=FALSE);
xFileStdInit:=TRUE;
uiFileStdState:=0;
ELSE
CASE uiFileStdState OF
0:(* create a new file *)
filop.sFileName:=sFileName;
filop.eFileMode:=FILE.MODE.MRDWR;
filop.xExclusive:=TRUE;
filop( xExecute:=TRUE);
IF filop.xDone THEN
hFile:=filop.hFile;
uiFileStdState:=1;
IF filop.xError THEN
(* error handling*)
1:(* close file - TestFile.txt *)
filcl.hFile:=hFile;
filcl( xExecute:=TRUE);
IF filcl.xDone THEN
uiFileStdState:=2;
IF filcl.xError THEN
(* error handling*)
2:(* end of example *)
END_CASE
IF NOT FiWr THEN
FiWr:= TRUE;
csvwrite:=0;
ELSE
CASE csvwrite OF
filop.eFileMode:=FILE.MODE.MAPPD;
IF filop.xDone THEN
hFile:=filop.hFile;
csvwrite:=1;
(* error handling*)
1:(* write text in the file *)
filwr.hFile:=hFile;
filwr.pBuffer:=ADR(FINSTR);
szFileSize1:=SIZEOF(FINSTR);
filwr.szSize:=szFileSize1;
filwr.udiTimeOut:=100000; (* 100ms Timeout *)
filwr( xExecute:=TRUE);
IF filwr.xDone THEN
csvwrite:=2;
IF filwr.xError THEN
(* error handling*)
2:(* close file - TestFile.txt *)
filcl.hFile:=hFile;
IF filcl.xDone THEN
csvwrite:=4;
(* error handling*)
3:(* end of example *)
END_CASE
I hope you can help :D
PostPosted: Wed Mar 14, 2018 8:02 am
Hi Primitive Source,
it seems we have kind of the same problem here, but you are one step ahead of me. So I also want to write & read a csv-file in a certain directory. As my code is mostly similar and you wrote
I want to ask you: Where is your file stored? And where in your code do you influence on where it's going to be stored?
Did you solve your problem? I know it's been one year already, but hopefully you care to help me a bit :wink:
Kind regards,
SpeedyG
PostPosted: Wed Mar 14, 2018 12:04 pm
Are you opening the file in write W or append A mode?
I've not looked at your library, but the one I used allowed me to open the file with append to add data - just be careful the file doesn't get too large.
Sent from my iPhone using Tapatalk Pro
