It is currently Sat Jul 22, 2017 1:58 am
PostPosted: Tue Jan 10, 2017 8:47 am
Hi all,
I'm using the Wago 750-880 with the 750-650 to communicate over RS232. I'm using the serial_interface_01.lib (http://www.wago.com/wagoweb/documentati ... 10901e.htm). With this library I am able to receive data, but not sending data. This is the code I have so far:
   COM2       : SERIAL_INTERFACE;
   xOpenPort2   : BOOL := TRUE;
   xInitPort2      : BOOL;
   xSendActive2   : BOOL;
   SendString2   : STRING := 'Msg from COM2';
   ReceiveBuffer2   : typRing_Buffer;
   index : INT;
index := index+1;
IF index = 1000 THEN
   xSendActive2 := TRUE;
IF index = 2000 THEN
   xSendActive2 := FALSE;
   index := 0;
COM2(   bCOM_PORT_NR   := 2,
   (*   cbBAUDRATE      := wBaudRate,
      cbsBYTESIZE      := bDataBits,
      cpPARITY         := bParity,
      csSTOPBITS      := STOPBITS_1,
      cfFLOW_CONTROL   := bFlowControl,*)
      utRECEIVE_BUFFER    := ReceiveBuffer2,
      ptSEND_BUFFER   := ADR(SendString2),
      xINIT         := xInitPort2,
           xOPEN_COM_PORT    := xOpenPort2,
      iBYTES_TO_SEND   := LEN(SendString2) +1,
      xSTART_SEND      := xSendActive2 );
Data should be sent when xSTART_SEND is TRUE? The function block does not reset this value to FALSE.
PostPosted: Wed Jan 11, 2017 11:50 am
Apparently, the module has flow control enabled.... So it works now.
PostPosted: Thu Jan 12, 2017 12:46 pm
if this counter is used as a type of counter then better use a task, you can time it.
and check if buffer empty before putting data in to buffer.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
