https://forum.codesys.com/
Wago 750-880 & 750-636 DC motor control
https://forum.codesys.com/viewtopic.php?f=2&t=7425
Page 1 of 1
Author:  sadmarpi [ Sun Dec 11, 2016 11:11 am ]
Post subject:  Wago 750-880 & 750-636 DC motor control
Dear CoDeSys forum,
I have the 750-636 module for controlling my 24v dc motor with incremental encoder and I would want to make a ladder program using MC1_DC_ControlBasic.
I know that the motor is working because in I/O-Check with few minor tweaks I'm able to set target position etc. and the motor is working. There is also a green light for the motor being referenced.
When I try to use the mentioned above function block, set the target value and speed (max. 200), and set the xEnable, I get an error flag and message that the motor is not referenced.
I'm guessing that I need to feed the function block more information, already tried few thing but failed.
Can someone tell me what do I do wrong? I would be glad to know and solve this problem.
Greetings to all.
Author:  shooter [ Mon Dec 12, 2016 11:03 pm ]
Post subject:  Re: Wago 750-880 & 750-636 DC motor control
there are several inputs you have to set, some of them via a structure.
try the example and it will clarify what you need.
or make an export and i will have a look at it.
https://www.phpbb.com/
