It is currently Thu Aug 24, 2017 4:02 am
PostPosted: Sat Nov 26, 2016 12:57 am
I try and save real assets from an energy meter.
But I'm not sure how I can do it.
I've used oscat_basic.lib and METER, METER_STAT to see my meter values. But how can I save real values every hour.
I want to log kW top average value for every houre.
Duration in minutes: M1, M2, M3, M4 ... M60
kW value: kW1, kW2, KW3, kW4 ... kW60
Average hourly kW value: H1, H2, H3, H4 ... H24
Then I want to save the 3 highest values for the months.
3 highest values in months: Mont_1_1, Mont_1_2, Mont_1_3, Mont_2_1, Mont_2_2, Mont_3_3 ... Mont_12_1, Mont_12_2, Mont_12_3
When a new year starts the values for the months will be overwrithen.
I need some help to start on how to do this. An example on how to store a value in specified intervals would be grate, what function blocks should I use? Please try to explain inn FBD or CFC.
Thanks for all the help
Espen (newbie)
PostPosted: Sat Nov 26, 2016 5:33 pm
Since you are already using Oscat basic, I suggest you look into the Oscat Network lib for this. It has the DATA_LOGGER component to store data. You can store in a CSV file on the PLC itself with the DLOG_STORE_FILE_CSV component. Or HTML, XML. Store on an SD card if your PLC has this. Use DLOG_FILE_TO_SMTP or DLOG_FILE_TO_FTP to have your PLC send the file to an email address or upload to an FTP server.
PostPosted: Sat Nov 26, 2016 6:25 pm
what PLC are you using, and where do you like to save the data.
and indeed have a look in oscat network.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Sun Nov 27, 2016 12:40 am
Thanks for your replay.
I now have a WAGO 750-849. Otherwise, I tend to use WAGO 750-831.
So it should work on both PLCs.
I read the documentation codesys_network_121_hf1
and thought DLOG_REAL can be used.
But when I enter lib file and compiles then I get an error message.
<Maximum number of POUs (1023) exceeded compile is aborted>
I changed the settings in <of target> maximum number of Pous 2023>
When I get errors
BASE64_DECODE_STR
BASE64_DECODE_STREAM
DLOG_DT
DLOG_FILE_TO_SMTP
XML_READER
I tried and create a new small program. With only a few blocks.
I increased max POUs and it gets compiled but with error on memory.
When I chose 'exclude unused' and got compiled and downloaded.
But how do I get used values from DLOG on.
Is there a better approach?
Espen (Newbie)
(Does this also as sign so I know what I've done and how I got it fixed.)
PostPosted: Wed Nov 30, 2016 11:11 pm
Hello.
I think I found an easier way and bring out the effects of each hour. And take care of the highest impact measured.
But I have not found any good solution and take care of the daily value so I can find the 3 highest values ​​in months. Or how to save the months view.
I thought ARRAY can be used. Also had been fine and could list the date, time measurements were from.
Do you have any good ideas? I have tested some, and tryied to find som more information.
Here is a link to the program.
https://www.dropbox.com/.../8cdsdg07... ... ter3.pro...
Espen
