It is currently Thu Jan 23, 2020 6:42 am
PostPosted: Fri Oct 28, 2016 9:30 am
I am coupling a Devicenet EL6752 Slave device with EtherCAT Coupler EK1100 through codesys v3.
I have made an Expert Process Data settings required size of input/output bytes as shown in image below.
The image below shows the startup parameters that I have configured so far.
The missing part so far is the mapping of the output/input data from/toward the master device with the input/output data on/from the slave device.
The problem is that I am not able to find a configuration settings for input/output connection polling data which can tell exactly at what index is the input data and at what index is the output data. So I am not able to exchange any data between the Devicenet master and slave devices. Can someone please suggest if I am doing it the correct way and is then how can I configure that data mapping between master and slave devices?
Thanks in advance.
IM
