It is currently Tue Jan 28, 2020 2:54 am
PostPosted: Thu Oct 13, 2016 11:04 am
For AND block one can use variable number of inputs.
I would like to create a function block with adjustable number of inputs e.g. of INT (or BOOL) type.
How to handle it inside the block?
PostPosted: Thu Oct 13, 2016 7:35 pm
In FBD you only can make a fixed number of inputs as you will have to declare them.
However you can make inputs and dont use them. you can set them in the declaration to a value, and when not used it will default to it.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Fri Oct 14, 2016 7:52 am
So how is the "AND" block made? Even if it is a function (and not a function block), it handles multiple inputs as defined by a user.
I am looking for a similar solution.
PostPosted: Sun Oct 30, 2016 9:21 pm
and block is made just as you say it item1 AND item2 AND item3 etc.
when doing your own functions you can not add them while programming, so do it while defining the FB. you do not have to use all inputs. (you can define the state of them.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
