It is currently Sat Nov 18, 2017 7:12 am
 Post subject: Functions
PostPosted: Fri Aug 05, 2016 12:34 pm
Hello!
I'm fairly new to programming and I'm struggling using Functions. I'm writing a piece of code that will use one timer for 4 applications within the program... I understand FB's but it's functions I'm unsure of. I'm not sure how to call the function, or how to get a result out of it...
The idea is to have a variable pulsed signal from the function, then use that multiple times and they will have their own setpoints... I've hit a wall at the moment, so any help will be appreciated.
Karl
 Post subject: Re: Functions
PostPosted: Fri Aug 05, 2016 9:13 pm
Functions do not keep memory - they are made to do some quick thing and that's it - no timers, no counters, etc. (there are ways around this, but avoid this - functions are for "a+b = c" type operations)
Use one FB to be your signal generator. You can then link the output to all four other FBs inputs.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Sun Aug 14, 2016 4:31 pm
Thanks for the reply!
In the end I used a function block exactly like you recommended! It took a while for the penny to drop where I was going wrong, but I guess that the point of learning something new! :)
I'm really getting into ST and IEC 61131-3!
Karl
PostPosted: Mon Aug 15, 2016 10:53 am
you can also time a task, i am running a standard blinker with a task on 100 ms.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
