It is currently Thu Jul 27, 2017 1:38 pm
 Post subject: modbus data types
PostPosted: Tue Jun 14, 2016 8:03 pm
Hello
I have been trying to get some tags from a nibe F1145http://www.nibe.eu/Products/Ground-source-heat-pumps/NIBE-F1145/
I use a modbus 40 connected to the heatpump.
http://www.nibe.eu/Products/Accessories/NIBE-MODBUS-40/
Here I have found out that I need to use -1 to the the rigth regestery. And that eks.
BT1 Outdoor temp is a WORD type under the <Modbus Master Configurator>
I wounder if it is any webpage og tabel that gives me informasjon about what kinde of datatype is rigth when I have the informasjon like thise.
Title            ID      -1      Unit   Size   Factor   Min   Max   Default   Mode
BT1 Outdoor temp   40004   40003   °C   s16   10      0   0   0      R
EB100-BE3 Current   40079   40078   A   s32   10      0   0   0      R
Software version      43001   43000      u16   1      0   0   0      R
Freeze Protection      43013   43012      u8   1      0   0   0      R
Accumulated energy   43230   43229   kWh   u32   10      0   9999999   0   R
EB108 Version      43580   43579      u16   1      0   0   0      R
Heat curve S1      47007   47006      s8   1      0   15   9      R/W
Codesys <Modbus Master Configurator> gives me these to pick from BOOL, BYTE, WORD, DWORD, SINT, INT, DINT, USINT, UINT, UDINT, REAL and STRING.
Thank you for your guide's into the mystery of datatypes
Espen Bø
 Post subject: Re: modbus data types
PostPosted: Tue Jun 14, 2016 10:07 pm
I found some info :D
I'm going to try thise tomorrow.
s16=WORD
s32=DWORD
u16=UINT
u8=USINT
u32=UDINT
s8=SINT
wish me luck :D
Espen
