It is currently Tue Oct 17, 2017 2:46 am
PostPosted: Fri May 27, 2016 5:12 am
Hi There,
I am using IFM CR1201, with CodeSys V3.5 SP8, but i am facing an issue while defining the retain variable. It does not give any error while compiling but when i try to download the program into the screen, it gives me
I am defining the variable as below:
VAR_GLOBAL RETAIN
hmiX1000_Digit : INT;
"Out of Retain Memory : Variable "hmiX1000_Digit", 2 bytes (Largest Contiguous gap 32724) (Incremental Compilation may produce fragmented memory. Perfrom "Build, Clean" to force a reallocation of all data and code."
Does anybody have come across with such kind of issue in CodeSys V3.5 with IFM Screen? if so and have found some solution, could you please help me out.
Thanks,
PostPosted: Mon May 30, 2016 6:09 pm
please use correct board forum as this is version 2.3
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Tue May 31, 2016 12:06 pm
for the CR1201, and all other ifm displays with Codesys V3, it's only possible to use "Persistent Variables".
unfortunately the compiler does not report an error...
Just add the object "Persistence Variables" to your Application.
Best regards,
mawa
PostPosted: Thu Jun 02, 2016 4:34 am
Hello Mawa,
Yes i have already tried "Persistent Variable" , it works. But just wondering why it is not working for Retain.
But anyway as you have mentioned that it does not support retain, but it is working with persistent, then there is no issue
