It is currently Wed Jul 26, 2017 1:38 pm
PostPosted: Fri May 20, 2016 11:28 am
I have a program written as a SFC but I now need to implement several instances of the program so I thought it best to have the code as a function block. Is there a way to convert the program into a function block or would I need to start again?
Thanks,
Tony
PostPosted: Sat May 21, 2016 1:19 am
Open the object. Change the word PROGRAM to FUNCTION_BLOCK above where your variables are defined. Close the object. It should switch to an FB. I use v3.x now and this is how it is done in 3.x, but if I remember correctly, it was the same on v2.3.
PostPosted: Sat May 21, 2016 12:07 pm
Thanks very much for your reply, I will try this.
PostPosted: Mon May 30, 2016 6:07 pm
not correct , as a program has no I/O defined.
however it is possible to do:
copy the program and give it other name (something like FB_SFC_blabla)
change indeed the name program to Function_block
now define what variables are used as Input
and as Output and which ones are global and local etc.
within the program no changes are needed.
check the real I/O Tags as you will mess it up when using double.
It is normal for a beginner to do it this way.
I only use Function blocks and my main program just calls blocks. so my main program is max one page, same for a sub btw make them max one page so you can overview what happens.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
