It is currently Tue Oct 17, 2017 1:13 am
PostPosted: Tue Apr 19, 2016 12:08 pm
I'm trying to make a very simple timing delay with Ladder, i've tried some coding, but i can't make it work.
I just want to add some delay after a pulse, wait a number of ms.
The problem with the TON is that the input signal must remain for the TON to become active. If the input signal is gone before the TON starts then there is never an output pulse. I want a pulse after a specific time after the input pulse, but my input is already 0 when the timer starts.
See my picture. Can anybody help me?
PostPosted: Tue Apr 19, 2016 12:38 pm
You will need to add a latched variable (SET coil) to your logic. Remember you have TON, TOFF and TP timers to work with.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Tue Apr 19, 2016 1:36 pm
Thanks for reply.
Sorry but i'm very stupid. Can you put an example please?
PostPosted: Tue Apr 19, 2016 6:15 pm
There are many ways, but here is one. I made it a function block so you can use it several times. Note - this version starts with rising edge of Start input and cannot be stopped - it will delay, then turn on Output, delay then turn it off again. Maybe not what you really wanted...
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Fri Apr 22, 2016 6:46 am
Just what I needed, thank you very much!
