It is currently Sat Jul 22, 2017 1:40 pm
PostPosted: Fri Apr 15, 2016 2:36 pm
Hi Everyone,
I'm trying to insert a Cold Reset of an application with the Appreset function.
Of course, if I start this from an application, it is stopped and I have to take control over Codesys to Restart it.
So I implemented a new Application that will only manage the Reset and restart of the main application.
This is well working 'manually', meaning that when I'm connected with Codesys and PC.
I would like now to be able to 'set' a bit on my main application that will trigged the reset abnd start sequence.
Unfortunately I can't find the way to exchange 'global' data from one application to the other one in the same PLC.
Does someone know how to perform this?
Thanks by advance
PostPosted: Fri Apr 15, 2016 6:28 pm
I found the definition of the Dataserver that seems to be the solution.
But when I try to implement it, I have the message 'no selected Provider'. for the datasource.
Do I need special library? Device?
PostPosted: Fri Apr 15, 2016 7:01 pm
here in the FAQ section:
viewtopic.php?f=22&t=5641&p=14007#p14007
but to be honest, usually this shound like a workaorund for restart fieldbus or for which use case is this
exactly the Workaround for? ;-)
PostPosted: Fri Apr 15, 2016 8:19 pm
Thanks for the feedback, I will check this... you are a really good source for my question...
Yes, you're right this is a workAround for restarting the Fieldbus in my case.
in fact, depending on our drives / devices, the Stop / Restart of the Ethercat may work or not. Sometimes, the ethercat of the drives restart well, but they stay in mode Drive interface Error...
I did not find a 'proper' way to restart the Ethercat in all the case.
So the reset Cold is a better way to do this. It has the advantage of resetting all the data for a clean new start.
PostPosted: Sat Apr 16, 2016 8:19 am
Unfortunately, the example show a reset cold of all the application present...
but when an application is reset cold, it is stopped... so a restart is not possible anymore, because the program is not running anymore.
I can't now test it for real because it involves Codesys 3.5.8 and our soft is released in 3.5.5, but when I translate it in my case, it stay in stop mode.
