It is currently Mon Jan 20, 2020 1:28 pm
PostPosted: Fri Jun 08, 2007 12:30 am
I'm new to IEC 61131-3 programming. Could someone clarify what the assignment operator (":=") in ST does when working with strings.
E.g. myString := originalString;
I was assuming this does a full character by character copy of the string, but I know in some lanuages only a reference pointer is copied. Now I wonder if my assumption is incorrect since there is string copy function in the system string library - SysStrCpy() in SysLibStr.lib.
I've had some strange bugs happening ever since I started using strings and SFC (SFCCurrentStep in particular) and want to make sure I am using strings correctly.
Any feeback on STRING usage is appreciated.
Sebastian Hutten
 Post subject:
PostPosted: Sat Jun 09, 2007 10:22 am
You are right. ':=' is a full character by character copy. (Certainly you may get a pointer to string see. ADR operator). Moreover you can use '=','>','<' in ST (but not '+', use CONCAT function). For example:
IF s2 = 'Shutten' THEN
s1 := CONCAT('Hello Mr.', s2);
I advice you to use string functions from Standard.lib (LEN, LEFT, FIND etc. see 'String functions' in the manual) instead SysLibs…. (platform dependent).
One limitation: do not use the same string functions in different tasks.
_IP_
PostPosted: Wed Mar 01, 2017 4:29 pm
Hi, its a very old topic but still valid. I have a question regarding the statement
I already found that recommendation or hint, that STRING functions from the standard library are not programmed to be reentrant.
Okay, usually its clear. But can you tell me why?
If I need STRING functions in POUs outsourced in libraries, do have to avoid the usage oif the functions from this Standard lib!?
Which should I use else?
Thank you for your support.
