It is currently Thu Feb 27, 2020 6:51 pm
PostPosted: Thu Oct 08, 2015 6:12 pm
I wrote some code which logs numerical data into an array. The problem is getting this data from the array into text, excel, or some other format where I can manipulate and analyze the data.
When I go online with a laptop, I can easily copy one array value and paste it into a text file. Unfortunately, I cannot determine a way to select multiple lines or copy the whole array of values. I can manually type out these values, but with hundreds of values it would take too long. I've tried logging remotely over CAN, but I cannot transmit and record at an acceptable speed. I really need these values logged as fast as the scan cycle will allow.
Any solution that I'm missing? I'm really surprised I can't just copy/paste a list of array values from codesys!
PostPosted: Thu Oct 08, 2015 9:48 pm
what plc and type is used, what communication can be used
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Fri Oct 09, 2015 1:48 pm
If you hardware has a flash drive or hard drive, then you can use the sysfile library for read/write access and just save your data as a csv type file.
If not, you can send the data via communications, like a serial stream, or as an email, etc.
I know you are using v2.3 based on the post folder, but for users using v3.x, they can also use Python scripting can access program variables - but that's only good for online mode.
Respond to shooter's post if you need more detailed information.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Wed Oct 10, 2018 2:57 pm
I am a new user of codesys, and i want to do the same thing.
I have a MOVI-C controller from SEW,
And I need to get values from codesys to excel.
I could put them in a trace, and then make a csv file from that trace, but there has to be a better way.
Also, this gives a measerment every cycle, or x cycles, and not when i want to.
my controller has 2 usb ports. I dont know if they can be used to write to. edit: they can"t be used to write to
I have tried some code that i found here for rasberry PI, to write to csv, but that won't download.
how do i know if my hardware has a flash/hard drive?
