s.magnussen - 2015-08-27
Hello.
I have a Wago 880 with a SD card slot, i'm using it with a datalogger function block. The problem with this is that the datalogger block (provided by Wago), is accumulating data in the .csv file, how can i make sure that the SD card wont be full after a time?
Is is possible to use the library "SysLibFile" and the function block "SysFileDelete" to delete files stored on the SD card. If so, how does "SysFileDelete" work, how do i activate it to delete the logfile on the SD card.
I'm using Codesys 2.3.
Simen.
