Unpacking a decimal
somlioy
2015-07-13
2015-10-27
  • somlioy - 2015-07-13
    Hello
    Got a word containing a decimal number which refers to some modbus registers on another plc.
    I'm aware I can use unpack for the first 8 byte, but what about those comming after?
  • shooter - 2015-07-13
    check oscat.de for a nice bundle of functions.
  • jethridge - 2015-07-23
    I recently needed to do something similar to what you are doing now. I checked the Oscat libraries, but ended up writing my own FB. However, I was shifting an array, not a register. You will most likely need to write your own function block using either BSR/BSL or the rotate command (ROL and another one, I think).
  • shooter - 2015-07-25
    probably you mean bits instead of bytes.
    you can use a word breaker (makes 2 bytes out of it, or you can use the wordvariable.0 etc.
  • Jonascox - 2015-10-27
    somlioy hat geschrieben:
    Hello
    Assign the word to a memory location such as %MW0.
    MYWORD at %MW0:WORD;
    Then assign variable names to each bit within %MW0.
    MYWORD_BIT_00 at %MX0.0:Bool;
    MYWORD_BIT_01 at %MX0.1:Bool;
    etc.
    Then each bit of your word is accessible and visible.
    IMG: Bild
