Counter that functions like TP timer
kmckinney
2015-07-01
2015-09-01
  • kmckinney - 2015-07-01
    I need a counter function that acts like a TP timer. Meaning when the counting begins the output goes high and remains high until the counting PV is reached. Once the PV is reached the output goes low. The program I am creating functions off a pulsing digital input and I need to count the pulses but keep an output on while it's counting.
    If you don't know of a built in function can you suggest to me a way I can create one with ladder logic.
    I appreciate any assistance I can get with this.
    Thank you
  • shooter - 2015-07-07
    so you need a downcounter, and when the start is true and the counter is NOT at zero the flag is TRUE.
  • kmckinney - 2015-07-08
    Yes, that is the concept. I've been trying to recreate with no luck/
  • shooter - 2015-07-09
    send an export file of what you made and i will give you the filling.
  • kmckinney - 2015-07-09
    I'm not exactly sure how to export so I'm sending a screen shot. HOPE this is ok
    IMG: Capture.PNG
    again:
    when you start counting you set a flag to ON
    when counter is at setpoint you reset the flag.
    that is all.
    you can use rising_edge to have this flag give a pulse to the next POU for example to close the bag because it is filled.
  • kmckinney - 2015-09-01
    Thanks Shooter
