The problem was that I had a variable in the function block with the same name as the action (variable name was zeroCount, action name was ZeroCount). This confused the compiler, so I renamed my action and now it works.
and you are also calling this function block twice (that is no good practice, however i do know why as you want the same blockresults.
You may give the values in front of the call.
Especcially when using timers this often is a problem, the compiler does not see these problems.
Using Codesys 2.3, I'm getting the following error:
"A function block call requires a function block instance."
My call to the function is in a PRG as follows:
Any idea why this won't build? The function block is instantiated, so I'm not sure what's going on. I suspect I might be calling the action wrong.
Thanks for any help!
I solved the problem.
