you will have to use pointers in this case.
off course you can compare the internal of the structures like VAR1.A3[1] etc.
In the oscat.lib is a function to do this.
hello,
I would like to know if it's possible to compare 2 variables when they are 2 structures.
For exemple, I have a structure
TYPE ST_HmiToPlc :
STRUCT
B1 : bool;
B2 : bool;
A3 : array[1..9] of bool;
I4 : int;
END_STRUCT
END_TYPE
I declare 2 variables
Var1 : ST_HmiToPlc;
Var2 : ST_HmiToPlc;
And know I would like to know if values in VAR1 are diffΓ©rents than values in VAR2
I wrote
if VAR1<>VAR2 then TOTO:=TRUE; end_if
But it's not correct, I have the fault ERROR 4011: Type mismatch in parameter 1 of ''<>'' : Cannot convert 'ST_HmiToPlc' to 'ANY_NUM'
Do you have a solution ? I don't want to compare each value of the structure because I have near 200 values in my structure.
I know you can do this :
VAR1 := VAR2;
without fault, so I think it's possible to make some calcul on the VAR1
however it is not 61131, but it works.
http://forum.codesys.com/viewtopic.php?f=11&t=5962
was also about this subject
Related
Talk.ru: 1
Thanks for your help.
I found some information on oscat to solve my problem.
