Simulation mode - Error 3101 Data area too large
Carlo
2014-10-01
2014-10-07
  • Carlo - 2014-10-01
    I'm writing a program (ST language) using codesys 2.3.9.42 and my target hardware is Wago 758-874, if I build the program without the simulation flag(Online - Simulation Mode) I have no error.
    The build process give this information:
    POU indices 1108 27%
    Size of used data: 672426 of 134217729 bytes (0.50%)
    Size of used retain data : 62444 of 1040128 bytes (6%).
    Now if I use Simulation and and I try to clean and build the same program I have 4 errors similar to this:
    Error 3101: Data area too large: 97177 Byte/s (95K). Maximum size: 65535 Byte/s /63K).
    Is it possible that in simulation mode Codesys has a memory limit that is smaller than the real limit of my target setting?
    Thanks.
    Carlo
  • shooter - 2014-10-01
    yes the simulation is limited, and is not dependent of the target, you can change this in sources
    if you have oscat the memory is very fast filled.
  • Carlo - 2014-10-02
    Where is the option to change the memory in simulation mode? I don't find "sources"..
    Thanks,
    Carlo
  • shooter - 2014-10-03
    it is in your target settings under resources
    (right bottom tab
  • sarathbabu - 2014-10-07
    Hi Carlo
     Did you Select PLCWInNT and in Target Settings go to Memory Lay Out to change no of POU and Memory Limit.
    Regards
    Sarath
