files generated when an application is build and download
praveena
2014-03-19
2014-03-19
  • praveena - 2014-03-19
    I have created an appication with my logic in PLC_PRG using Function block diagram(FBD). When i build the appication, some files must be generated.
    What type (bin or exe) files are generated ,when an application is built and where (path on hard disk) do these files reside?
    There is an option called "Generate Code" .On clicking this, the code ios generated but where does it reside?
    praveena
  • shooter - 2014-03-19
    under project options directories you can find where they are in default.
    with me it is C:\ProgramData\CoDeSys V2.3\Compile\ so not in program files but in data.
