Currently using Version 2.3.9.34 with an ABB AC500 PLC (PM591).
I am trying to get the timing between two events. I won't go into high detail, let's just say, for the sake of discussion, when either of the two events occur, they set a corresponding boolean variable = TRUE.
So, if Machine Starts, bStart = TRUE.
And, if Machine Stops, bStop = TRUE.
I'm over simplifying to make this easy to answer.
I just need the elapsed system time between the two events. Here is the code I am currently using:
(* SYSTEM TIME *)TIME_SYSÂ Â :=SYS_TIME(TRUE);TIME_ENDÂ Â :=TIME_SYS;(* RTC IN SECONDS *)RTC_TIMEÂ Â :=SysRtcGetTime(TRUE);TIME_END2Â Â :=RTC_TIME;(* EVENT TIMER *)RTRIG(CLK:=ESC_FAULT,Q=>);Â Â Â Â (* START TIMER Â Â *)FTRIG(CLK:=ESC_RUN,Q=>);Â Â Â Â (* STOP TIMER Â Â *)IFRTRIG.QORFTRIG.Q=TRUETHENÂ Â COUNTÂ Â Â Â Â Â Â Â :=Â Â COUNT+1;Â Â EVENT_TIMEÂ Â Â Â Â Â :=Â Â TIME_END-TIME_START;Â Â TIME_STARTÂ Â Â Â Â Â :=Â Â TIME_SYS;Â Â EVENT_TIME2Â Â Â Â Â Â :=Â Â TIME_END2-TIME_START2;Â Â TIME_START2Â Â Â Â Â Â :=Â Â RTC_TIME;END_IF;
The two times are redundant. One is DWORD and the other is DT format.
This seems to work in my current configuration, but if I want to test a scenario where the event is defined by a value reaching or exceeding a set point, it doesn't seem to function properly.
Does anyone have a function block they use for timing system events?
Any help is surely appreciated. Thanks!
FUNCTION_BLOCKTIMER_SYS(*INPUTVARIABLES Â Â *)VAR_INPUTÂ Â bSTART:BOOL;Â Â bSTOP:BOOL;END_VAR(*OUTPUTVARIABLESÂ Â *)VAR_OUTPUTÂ Â dwLAP_TIME: Â Â DWORD;END_VAR(*LOCALVARIABLESÂ Â *)VARÂ Â dwTIME_SYS: Â Â Â Â DWORD;Â Â dwTIME_END: Â Â Â Â DWORD;Â Â dwTIME_START: Â Â DWORD;Â Â rtSTART: Â Â Â Â R_TRIG;Â Â rtSTOP: Â Â Â Â R_TRIG;END_VARdwTIME_SYSÂ Â :=SYS_TIME(TRUE);dwTIME_ENDÂ Â :=dwTIME_SYS;rtSTART(CLK:=bSTART,Q=>);Â Â Â Â Â Â Â Â (*STARTTIMER Â Â *)rtSTOP(CLK:=bSTOP,Q=>);Â Â Â Â Â Â Â Â Â Â (*STOPTIMER Â Â *)IFrtSTART.QORrtSTOP.Q=TRUETHENÂ Â dwLAP_TIMEÂ Â Â Â :=Â Â dwTIME_END-dwTIME_START;Â Â dwTIME_STARTÂ Â Â Â :=Â Â dwTIME_SYS;END_IF;
Now, I have this function block to use to find the time between two events:
Time is output to dwLAP_TIME in milliseconds.
Feel free to use this!
Hey Guys!
yes have a look at w www.oscat.de w it is english library for codesys with lots of functions etc.
keep all times in DT format easier to work .
I simplified the code:
