I am new to this forum and I am just beginning to us codesys.
I am trying to get communication between berghof EC1000 and roboteq 2130. I am using 232 serial port. I am using a program I got from the codesys store ( http://store.codesys.com/serial-com.html ). I am using Codesys v3.5 SP1 Patch 4.
My problem is that I can send one message through the serial port whit out any problems, but when I try to do it again nothing happens. Then I have to logout from the project and download it again to be able to send the messages again.
Can anybody please help me with this problem?
IF xPortOpen THEN
//The first Port is opened with the given parameters
como1(xExecute := TRUE, usiListLength:=SIZEOF(aCom1Params)/SIZEOF(COM.PARAMETER),pParameterList:= ADR(aCom1Params));
IF xWrite THEN
// the write process is started for the first port
comw1(xExecute := TRUE,hCom:= como1.hCom,pBuffer:= ADR(sWrite),szSize:= SIZEOF(sWrite));
Hi
check the handshake and do you close the communication after sending.
Think you for your replay.
I have tried it with and without handshake. I have also tried it without closing the port between sending messages. Here is the code I am using.
IF xStartTest THEN
IF xPortOpen THEN
IF xWrite THEN
IF xPortClose THEN
