It is currently Tue Mar 19, 2019 5:48 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sat May 11, 2013 9:37 am
hello, all
how i can convert and save REAL to Byte[]? also from byte[] to REAL?
I tested with SysMemCpy(), it goes in, but if the address of Byte[] elements are not continuous, then it might problem.
br/
listenyang
PostPosted: Mon May 13, 2013 9:07 am
you are talking about two different things
real to byte is just REAL_TO_BYTE
however you want to have the bytes this is done with pointers.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Tue May 21, 2013 12:30 pm
If you are just looking to pack the real data into an array of bytes, the easiest path seems like it would be to create your real and your byte array at the same marker address. Then they are actually at the same place in memory.
nOrM
nOrM = Norman Dziedzic Jr.
PostPosted: Wed May 22, 2013 9:59 am
The most robust way is to use a UNION!
TYPE uRealBytes :
  UNION
    rValue : REAL;    // Needs 4 Bytes in memory
    abValue:  ARRAY [0..3] OF BYTE;
  END_UNION
END_TYPE
Then you kann fill in a real by "uRealByte.rValue := <some real>;
In "uRealByte.abValue[n] you have the Bytes to copy to ...
The conversion back is done in the same way.
PostPosted: Wed May 22, 2013 1:20 pm
Are there Unions in V2? My brain doesn't think in V3 yet
nOrM
PostPosted: Thu May 23, 2013 3:23 am
thanks your reply, REAL need 4 bytes, so i need fill in a BYTE[0..3], NOT into a single BYTE.
TYPE uRealBytes :
  UNION
  END_UNION
END_TYPE
thanks you reply, this is great! :D
PostPosted: Tue Jun 11, 2013 5:23 pm
I’m not familiar with UNION. But I like to test this.
Where do I define this Union type?
I tried under “Data Types” but then I get the error “unknown type:UNION”
PostPosted: Tue Jun 11, 2013 5:29 pm
union does exist in V3 not in V2.3
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
PostPosted: Thu Jun 20, 2013 1:44 am
This can easily be done be using fixed mapping to your variables. Most CoDeSys controllers have fixed memory address. If you map a REAL and Byte array to the same memory location it will all you read the REAL as individual bytes. This method will work in all versions of CoDeSys. Below is an example how:
myReal AT %MD0 : REAL;
myByteArary AT %MB0 : ARRAY[0..3] OF BYTE;
To give you a better understanding how the memory map works refer to my other post for an excel sheet.
viewtopic.php?f=2&t=5045#p8228
The Original SoMachine Ninja
PostPosted: Thu Feb 23, 2017 4:11 pm
I have made a simple yet flexible function which uses the pointer to memory trick, it uses a user defined struct for it to work.
The code is made in CodesysV2.3 but will also work in Codesys V3 (but in V3 a Union is shorter though)
TYPE ST_BYTE_TO_REAL :
STRUCT
   B0:   BYTE;
   B1:   BYTE;
   B2:   BYTE;
   B3:   BYTE;
   REAL_OUT : POINTER TO REAL;
END_STRUCT
END_TYPE
The function fills the STRUCT and returns the correct decimal number from the byte array with use of a pointer.
(* The function assumes that the 4 bytes are allready formatted according to IEEE Standard 754 Short Real Number *)
FUNCTION BYTES_TO_REAL : REAL
VAR_INPUT
   B3:   BYTE;
   B2:   BYTE;
   B1:   BYTE;
   B0:   BYTE;
   CONVERT: ST_BYTE_TO_REAL;
(* Initialise POINTER to address of B0 *)
CONVERT.REAL_OUT := ADR(CONVERT.B0);
(* Fill bytes *)
CONVERT.B0:=B0;
CONVERT.B1:=B1;
CONVERT.B2:=B2;
CONVERT.B3:=B3;
(* Return ptr^ (value at adress) *)
BYTES_TO_REAL := CONVERT.REAL_OUT^;
(* END *)
The function can be adapted long reals (8 Bytes) or any other user specific need.
Good luck!
PostPosted: Thu Feb 23, 2017 7:49 pm
the problem was in 2013, however it is a solution.
have a look at oscat.de for more functions.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
