It is currently Fri Feb 21, 2020 10:32 am
PostPosted: Mon Jan 21, 2013 4:09 pm
i got following problem:
I reset my plc's using command SysResetPlcProgram(x); (x = 0,1). After reset my program, which is running on the plc, the program stops.
Is there anyway to run the program again, without doing this manually by starting the application by hand (F5) ?
PostPosted: Tue Jan 22, 2013 8:30 am
why do you reset,
is the plc autostart (on wago it is a switch)
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Tue Jan 22, 2013 9:38 am
I want to test some functions with persistent and retain variables, after cold reset and warm reset. If i add an boot application the plc prog autostarts (there is no switch or something at my plc / autostart is enabled) until the first reset in the code. From there i have to log in the debugger and continue the program manually.
PostPosted: Tue Jan 17, 2017 3:22 pm
Did you solve this? I'm experiencing the same problem. After SysResetPlcProgram(RESET_COLD); the boot project is not automatically loaded.
PostPosted: Wed Jan 18, 2017 3:25 pm
you have to make the project bootable.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
