It is currently Mon Jan 20, 2020 12:25 pm
PostPosted: Thu Jan 20, 2011 11:17 am
Hello
I'm trying to write a function block (in ST) that shall do some operation on an array.
Preferbly the size of the array should be defined by a VAR_INPUT
Currently the variable declarations are as follows.
VAR_INPUT
Ellements:INT;
NewVal:INT;
VAR_IN_OUT
History: ARRAY [1.. 10] OF INT;
My intention is to replace the fixed size ARRAY[1..10] to [1..Ellements] e.g. a programatically
changeable number of ellements in the array.
Anyone ?
PostPosted: Mon Jan 24, 2011 1:24 pm
use a integer pointer as input;
VAR_INPUT
  Value:INT;
  History: POINTER TO INT;
  Item: POINTER TO INT;
Item:= Temp;
FOR I:= 1 to Size do
  Temp^:= Value;
  Temp:= Temp + SIZEOF(Temp^);
END_FOR;
Andreas
http://www.boschrexroth.com
PostPosted: Mon Jan 24, 2011 7:18 pm
I've never thought to accomplish an array this way. Would you mind clearing up a few details?
1. What is the purpose of the input variable, History?
2. Where are you defining "temp" and is it another Pointer?
3. If you wouldn't mind briefly explaining what's going on in your example, that'd be very helpful; it'd be great to really understand what's going on here.
Thanks! :)
PostPosted: Mon Jan 24, 2011 10:36 pm
Hello
I've not tried the suggestion by Andreas yet, will do when time let me.
The variable History is a set of samples of an input. I want to do some calculation on them
and treat the array as a FIFO. All this is not a problem.
The question is related to how to declear an input as an array of unknown size at compile time.
All I've tried so far is not valid syntax
PostPosted: Fri Jan 28, 2011 9:32 am
Thanks! :)
#1: It's the same as the history in your example, a input array of values, but instead of just writing History as the input you write Adr(History[0])
#2: My bad, all Temp should be Item
#3: Basically my example just fills the input history with the value;
VAR_INPUT
  Size:INT; (* Size of the array *)
  Value:INT;
  History: POINTER TO INT; (* Same as History: ARRAY[0..Size-1] OF INT; *)
(* Just save a local copy of History[0] *)
Item:= History;
  (* History[I]:= Value; *)
  Item^:= Value;
  (* Goto the next item in the array *)
  Item:= Item+ SIZEOF(Temp^);
END_FOR;
Andreas
PostPosted: Mon Jan 31, 2011 5:30 pm
if you are interested you can find many array functions in the open source library OSCAT.
many of the array functions use pointer to operate on unknown size of arrays.
you can use our source code as sample to develop your own functions
freie sps bibliothek unter www.oscat.de
PostPosted: Tue Mar 07, 2017 12:17 pm
VAR_INPUT
   NewVal:INT;
VAR_IN_OUT CONSTANT
   Ellements:INT;
VAR_IN_OUT
   History: ARRAY [1..Ellements] OF INT;
