I have fund something very strange. The value in a variable follow the value in an other variable without assigment bettween there.
Focus on code:
VAR_GLOBAL
StateLanguage: INT:=0;
END_VAR
VAR
LastLanguageTime: INT; change_Language: BOOL;
IF StateLanguage<>LastLanguageTime THEN
LastLanguageTime:=StateLanguage; change_Language:=TRUE;
END_IF
IF change_Language=TRUE THEN
(*lot of things*) change_Language:=FALSE;
Describe of the problem:
The 2 local variable are not used in other part of the project (not 2 times the same name).
I download the program in the board and go in debug mode.
When StateLanguage is 1, LastLanguageTime become 1 and change_Language is lock at TRUE.
When StateLanguage is 2, LastLanguageTime become 2 and change_Language become " INVALID: 16#02 ".
If I forced change_Language to FALSE, LastLanguageTime was locked to 0 and StateLanguage continu to evoluate in function of other part of the program.
Tried things:
Change names of variables.
Change position of declaration of these variables.
Precision:
My code use almost all the memory. What append with CoDeSys if we need more variables than possible in memory?
CoDeSys 2.3.4.1 and Target Controler Inside
Thanks,
Focus on code:
VAR_GLOBAL
END_VAR
VAR
END_VAR
END_IF
END_IF
Tried things:
Precision:
Thanks,
