It is currently Wed Feb 19, 2020 9:27 am
PostPosted: Fri Jan 24, 2020 3:43 pm
First steps in codesys...
Is there an equivalent to IF-Then-Else or Case in the FBD language? It seems to exist in the ST and I naively assume the you could do in FBD the same as in ST. :)
thanks, J.
PostPosted: Fri Jan 24, 2020 5:43 pm
For IF-THEN-ELSE:
SEL is an idiomatic way, if (and only if) the two branches do not have side effects.
An ugly way is using a chain of boxes each with EN/ENO.
But please, even if you can write a FOR loop in Ladder, it does not mean it is a good idea. If you are unable to avoid side effects in branches, it is better to stay in ST: the resulting code will be more clear to others (including your future self).
