It is currently Wed Feb 19, 2020 9:40 am
PostPosted: Wed Jan 22, 2020 9:32 am
I am sending broadcast message and within PGN there is 12 bit signal (Codesys 3.5 SP11+ 32 bit) with conversion info:
Conversion: TRUE
Raw data type: Signed
Byte order: Little endian
Scaling 1
Offset 0
IEC datatype: INT
(min and max values are -180 to 180)
And when "online" the value is e.g. -175.
When I am reading that CAN message from other controller and I am watching it Online, the values coming are fine for 0..+180 (same 0..+180), but negative values from -1 to -180 are 3917 to 4095 ?? It's like the Signed is not working?
The "reading" controller PGN signal conversions are same :
Conversion: TRUE
Scaling 1
Offset 0
IEC datatype: INT
"Reading" controller is with Codesys 3.5 SP15 Patch 1 + (64 Bit)
Why the value is like it's Unsigned UINT? What I am doing wrong or is it a bug?
PostPosted: Thu Jan 23, 2020 11:10 pm
Hmm, it is clear you have a 12bit 2's compliment signed integer, whose data is stored in 16 bit 2's compliment signed integer.
You can write a FUNCTION to convert the two data types.
FUNCTION SIGNED12_TO_INT : INT
VAR_INPUT
    Signed12 : INT;
//IF Bit 12 is already on, then we know it is a negative number and must convert
IF Signed12.12 THEN
    SIGNED12_TO_INT := TO_INT(TO_UINT(Signed12) OR 16#F000); //SET the highest 4 bits
ELSE
    SIGNED12_TO_INT := Signed12;
END_IF;
PostPosted: Fri Jan 24, 2020 2:03 pm
And if you set "Raw data type" (a.k.a. on the wire) as "Unsigned" and set "Offset" as -180?
It is also more idiomatic (by the J1939 standard, all quantities on the wire are, or at least should be, unsigned).
By the way, if it is an angle, have you checked the standard angle scalings? There is SAEad04 which uses two bytes, 1/128 deg/bit, and offset -200, for a total range of -200 .. +301.99 degrees.
