A Generic Error Occurred in GDI+
2020-01-20
2020-01-21
  • JoseMaPerez - 2020-01-20
    I have two projects: C and I, and SEC. Both use the same version of Codesys, V3.5 SP15 patch 1. Both are running on identical PAC controllers. I can run the C and I project on my PC and stay logged in all day. However, for the SEC project, my CODESYS crashes after about 10 minutes after logging in. What I get is a:
    "Unhandled Exception has occurred in your application....
    A generic error occurred in GDI+"
    I'm trying to attach a text document with the details of the error. Can someone help me identify the issue I'm having with this project?
    Thank you!
    Jose
    GDI error from 1 20 2020.txt [130.56 KiB]
  • JoseMaPerez - 2020-01-21
    I believe I figured it out. If I log in using the device name rather than the IP address, it stays logged in.
    Jose
