I have two projects: C and I, and SEC. Both use the same version of Codesys, V3.5 SP15 patch 1. Both are running on identical PAC controllers. I can run the C and I project on my PC and stay logged in all day. However, for the SEC project, my CODESYS crashes after about 10 minutes after logging in. What I get is a:
"Unhandled Exception has occurred in your application....
A generic error occurred in GDI+"
I'm trying to attach a text document with the details of the error. Can someone help me identify the issue I'm having with this project?
Thank you!
Jose
GDI error from 1 20 2020.txt [130.56 KiB]
I believe I figured it out. If I log in using the device name rather than the IP address, it stays logged in.
Jose
