It is currently Sat Feb 22, 2020 1:03 am
PostPosted: Tue Jul 23, 2019 6:22 pm
I have started to setup a continuous integration for our project using the python api and have noticed that when loading/running project with the svn add on , codesys can leave some objects in the svn tree locked.
Can anyone advise how python API can be used to request codesys runtime not acquire any SVN locks ?
At the moment we run this code snippet in a non-codesys checkout of the project to clear locks but it would be better to prevent them from being used at all.
    def unlock_project(self, path):
        output = subprocess.check_output(['svn', 'status', '-u', path]).splitlines()[0:-1]
        for line in output:
            line_str = line.decode(encoding='utf-8', errors='replace')
            locked_path = line_str.split()[2]
            print('Found locked path at: "{0}"'.format(locked_path))
            force_lock = subprocess.check_output(['svn', 'lock',  locked_path, '--force'])
            print(force_lock.decode(encoding='utf-8', errors='replace'))
            remove_lock = subprocess.check_output(['svn', 'unlock', locked_path, '--force'])
            print(remove_lock.decode(encoding='utf-8', errors='replace'))
Any advice gratefully received,
Kind regards
Varley
PostPosted: Mon Jul 29, 2019 9:44 am
Hi Varley.
Depending what you want to do you may set the project to offline mode or disable locking.
proj = projects.primary
# Disable locking for the whole machine
svn.default_auto_locking_mode = SvnAutoLockingMode.Never
# Deisable locking for the current project
proj.svn.project_auto_locking_mode = SvnAutoLockingMode.Never
Martin
PostPosted: Wed Aug 14, 2019 5:21 pm
Hi Martin,
Thanks - that works just fine, although we may still need to force the unlock in case some team member has left the project locked by accident.
Best regards
Varley
PostPosted: Tue Aug 20, 2019 8:17 am
Hi Varley.
If it is a object in a project, which is under version control, you can use the following code to unlock it:
if obj.svn.is_versioned and obj.svn.is_locked:
   obj.svn.unlock()
Martin
