It is currently Tue Feb 18, 2020 7:19 am
PostPosted: Fri Apr 05, 2019 6:14 am
Hi everyone,
Unfortunately I havent found anything regarding my question using the search function.
Here is my question:
I want to connect 4 serial devices to the 4 USB ports on Raspi. All 4 devices are exactely the same (Roboclaw motor controller).
Using udev rules I am able to give all of them reproducable names, even if I disconnect and reconnect them, so thats all fine.
To use the serial USB in codesys I know that I need to add the following lines to CODESYSControl_User.cfg:
[SysCom]
Linux.Devicefile=/dev/ttyUSB
portnum:=COM.SysCom.SYS_COMPORT1
After this I am able to control the devices vial the CAA serial library.
My question is now if there is a way to assign each Motorcontroller to a specific comport, so that I can decide which motorcontroller to "speak" without sending every command to each motor?
Thank for any help!
PostPosted: Tue Apr 09, 2019 3:01 pm
Hi pdoubleu,
you can bound the COM-Port Number to the USB-Port, by specifying the USB-port path.
And then you can use the COM-Port numbers for a single motor, for example COM-Port number 1 for motor 1 and COM-Port number 2 for motor 2 and so on.
I've got a little instruction for this:
First let's identify the name of the interface, by using the attribute ATTRS(interface}.
So we can make sure that only a device, with the correct interface name, is "linked".
To check the attributes of a plugged-in device, use following code:
 udevadm info --name /dev/ttyUSB0 --attribute-walk
It will show you the information, from parent device to parent device. So the first info should be something like this:
 looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0':
    KERNEL=="ttyUSB0"
    SUBSYSTEM=="tty"
    DRIVER==""
So go ahead and look for the attribute "ATTRS{interface}"
This attribute gives you the name of the plugged-in USB extension.
  looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0':
    KERNELS=="1-1.4:1.0"
    SUBSYSTEMS=="usb"
    DRIVERS=="ftdi_sio"
    ATTRS{authorized}=="1"
    ATTRS{bAlternateSetting}==" 0"
    ATTRS{bInterfaceClass}=="ff"
    ATTRS{bInterfaceNumber}=="00"
    ATTRS{bInterfaceProtocol}=="ff"
    ATTRS{bInterfaceSubClass}=="ff"
    ATTRS{bNumEndpoints}=="02"
    ATTRS{interface}=="<Name of the device>"
    ATTRS{supports_autosuspend}=="1"
Now you can create a udev rule, by editing your udev rule file and add:
SUBSYSTEM=="tty", KERNEL=="ttyUSB*", KERNELS=="1-1.4:1.0", ATTRS{interface}=="<Name of the device>", SYMLINK+="ttyRS0"
The Parameter KERNELS=="1-1.4:1.0" is the fixed path of the usb-port.
So this device will now always have the COM-Port number 1. If you want to add another device and you want to skip Com-Port number 2, you can use following rule:
1.) Find out the name of the interface again
2.) Check the USB-Port path.
3.) add your rule as you want :)
SUBSYSTEM=="tty", KERNEL=="ttyUSB*", KERNELS=="1-1.3:1.0", ATTRS{interface}=="<Name of the other device>", SYMLINK+="ttyRS2"
What we also did, is to create a SYMLINK. This will avoid further problems, in case of that you're using different devices, like "ttyAMA" or something else. Because as far as I know, you can specify only one Device file name in the codesyscontrol config file, so you can avoid further troubles.
In case of that, you have a totally different device, you can also use other devices.
Example:
SUBSYSTEM=="tty", KERNEL=="ttyAMA*", KERNELS=="1-1.2:1.0", ATTRS{interface}=="<Name of the ttyAMA device>", SYMLINK+="ttyRS3"
The CODESYSControl_User.cfg should look like this:
[SysCom]
Linux.Devicefile=/dev/ttyRS
I think you don't need the last parameter "_:=...". But I'm not sure.
I hope this little instruction helps you.
Let me know if I missed something.
PS: I think this post should be moved to the raspberry pi forum category.
Building & Process Automation with HVAC Library for CODESYS© - www.hvac-automation.com
PostPosted: Tue Apr 09, 2019 3:51 pm
After writing the instruction, I've checked the forum and have seen, that there is already an instruction available:
Check this link:
viewtopic.php?f=23&t=6247&start=30
