It is currently Mon Feb 24, 2020 10:19 pm
PostPosted: Thu Feb 21, 2019 10:37 am
I want to create the files for a boot application with a script for later software deployment on one or multiple plc.
I use the function: "app.create_boot_application(path,True,True)"
So long this works great. I get the application.app, application.crc files and visu files etc.
But when i have ethercat in the project this boot application does not run the ethercat.
I assume that with the script engine not all files for the boot application are created. Because when i use the UI-button to create the bootapplication i get an additional File:
*ecat_master_0_boot.xml
and Folders:
*ParameterSets
*PlcParameterSet
*ProfileData
*SoftPlcParameter
Is there a way to get this with scripts?
(I am using Lenze PLC Designer 3.15 working on Codesys 3.5.9)
Thanks and best regards.
PostPosted: Mon Oct 14, 2019 8:28 am
I think the reason for this behavior is because Lenze modified the command to create a boot app in their IDE GUI, but not in the script engine.
In system.commands i found two commands to create a boot application.
One seems to be the command called with IScriptApplication2.create_boot_application Method documented in the API. With this i only get the .app and crc. files and not the ecat_master_0_boot.xml.
But the second command is named "Erzeuge Bootapplikation für Lenze Geräte" seems to be the euqivalent to the GUI button.
I called it like this and it works and creates all the files in the output path:
system.commands['{4913bcdd-6e61-43d9-ac60-e4c8c82ac405}'].execute(path)
Only downsite: I dont know if this supports the other two bool parameters (bool update_compile_info,bool write_visu_files). I tried to call it with (path,True,True) but didn't work.
